November 12, 2021, 06:00 |
User Routine, Schiller Naumann
Rep Power: 7 |
I want to modify the equation of the (Schiller Naumann) drag model to include some terms and make it valid for nonspherical particles. Is there anyway to do that without using Fortran and User Routines ? If no, are there any tutorials explaining how to use User Routines ? |
November 14, 2021, 16:55 |
Rep Power: 144 |
Set the Drag Force to "Particle Transport Drag Coefficient" and then you can define your own function for the drag coefficient. You can define this drag function by user fortran or CEL.
November 15, 2021, 03:09 |
Rep Power: 7 |
Hi Glenn,
When I did that, I got this error: ( Parameter 'Drag Coefficient' in object '/FLOW:Flow Analysis 1/DOMAIN:Inlet_Rotor_Outlet_Grob/FLUID PAIR:Fluid 1 | Kalkpartikel/MOMENTUM TRANSFER/DRAG FORCE/DRAG COEFFICIENT' is not allowed to be assigned an expression value that depends on variables. It must be assigned a numeric value, or an expression that resolves to a constant value.) While I don't want to set the drag coefficient as a constant value but it should be variable depending on other parameters such as the Reynolds number which is not constant in the whole domain but it varies also depending on the flow and particle velocities. |
November 15, 2021, 03:14 |
Rep Power: 144 |
That is disappointing. Limiting it to constant variables is very unfortunate.
Oh well, then your only option is the existing models or user fortran.
November 15, 2021, 03:22 |
Rep Power: 7 |
Do you know any tutorials for using User Fortran ?
I have read the CFX documentation, but it is not clear to me how to compile the (.F) file for CFX. |
November 15, 2021, 03:32 |
Rep Power: 144 |
You need to make sure you have the supported compiler for your version of CFX. The documentation covers all that and a few simple tutorial examples.
calculate particle temperature gradient with user routine | amd18 | CFX | 1 | April 3, 2017 11:32 |
User fortran to input/output file in a parallel run | doublestrong | CFX | 5 | March 31, 2017 08:15 |
What is the diameter of droplets in Schiller and Naumann model for fluid-fluid drag? | betelnut | OpenFOAM | 0 | November 4, 2010 21:33 |
CFX 10 User Routine NOT in Fortran | Andre | CFX | 14 | August 8, 2006 23:03 |
SOURCE TERM USER ROUTINE | Mario | Siemens | 2 | April 26, 2001 12:15 |
