pressure change in CFX 11
Old   May 8, 2007, 10:26
Default pressure change in CFX 11
Greg
I'd like to implement a pressure change between two faces with a domain interface in CFX 11. So I created an domain interface between the two sides and as Interface Models I have the choice between "General Connection" and "Translational Periodicity". In both options I can input a pressure change in Pascal. My problem is that I don't really know what to choose from these two things. Has anybody a good example or tutorial for pressure change in CFX?
Thanks for your help
Old   May 8, 2007, 11:05
Default Re: pressure change in CFX 11
Robin
Use General Connection.
Old   May 8, 2007, 11:34
Greg
Thanks for your quick answer.
I have selected the General Connection option and the solver crashes immediately after the start with the error message "No control surfaces have been found at all for airinterface. To work around this please set the expert parameter "ggi permit no intersection = t"". When I set this parameter to true, the run does not converge.
Greg
Old   May 8, 2007, 16:05
Robin
Did you pick faces for the interface? I assumed by your earlier description that it was an internal face, in which case you would use General Connection. If it is a periodic connection (i.e. what goes out one end comes back in the other) then you should use the periodic connection instead.
This is all explained fairly clearly in the documentation.
-Robin
the pressure coefficient vs angle in CFX?? Jwolf CFX 1 December 14, 2012 08:31
negative pressure in cfx flar.t CFX 1 December 19, 2006 00:20
pressure change and angular velocity Mangnan CFX 2 June 25, 2004 20:26
CFX pressure based clifford bradford CFX 12 June 20, 2001 00:03
How to obtain correct viscous pressure drag using CFX? Ketut Utama Main CFD Forum 1 January 25, 1999 06:05
