Temperature dependent viscosity
Like Tree6Likes
  • 2 Post By Opaque
  • 1 Post By evcelica
  • 1 Post By Mayank Shakya
  • 1 Post By QaisKhraisat
  • 1 Post By ghorrocks
Old   November 3, 2021, 08:38
Default Temperature dependent viscosity
Qais
QaisKhraisat is on a distinguished road
Hi Everyone,
I am trying to simulate a water lubricated bearing on CFX. With that in mind, I want to take into consideration the viscosity variation with temperature. The attached photo shows the relation between the kinematic viscosity [cSt] and Temperature [K]. I would like to import this formula into CFX, and I tried writing an expression, but without any success.
Can anyone explain to me on how do that please?
Note:
a, n, and m are constants.
Thank you very much in advance!
QaisKhraisat is offline   Reply With Quote
Old   November 3, 2021, 09:26
Opaque will become famous soon enough
That is an implicit formula for kinematic viscosity as a function of T.
Which explicit form of that formula did you attempt to use? We (forum members) can then help you with the CEL details
evcelica and karachun like this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   November 3, 2021, 10:03
Qais
Thanks for the reply Opaque!
The formula was based on MacCoull and Walther's relation which is provided in the literature in its implicit form. The image in this link (https://1drv.ms/u/s!AkCnaOk1rReFzULinQPjc1_aurxy) shows the formula in its original form.
Is it possible to write it in this form into CFX?
Old   November 3, 2021, 11:05
ANSYS CFX expects a formula for viscosity explicitly, say
Dynamic Viscosity = F (T)
In your case, you must solve for "nu" as a function of T
nu = density * ( 10** ( 10 ** ( ...) ) - a)
Just be careful to keep all the evaluations within bounds.
Old   November 3, 2021, 11:07
Qais
Thanks for the advice!
Old   November 3, 2021, 20:11
Erik
evcelica is on a distinguished road
MathCAD is great at algebra, see attached image.
And then viscosity written in CEL: = -Aconstant + (10^((10^Nconstant)/((TempUnitless)^Mconstant)))
Define TempUnitless as Temperature*1[K^-1] (if it is in units of K)
You can plot your expression when defining it to make sure it is what you expect.
karachun likes this.
evcelica is offline   Reply With Quote
Old   November 5, 2021, 06:04
Qais
Thanks for the reply and advice Evcelica!
Old   August 18, 2022, 07:48
Mayank Shakya
Mayank Shakya is on a distinguished road
Hello
I am also working on the same problem, but facing problem. The solver is ending up with error.
If any one can help please suggest what I can do.
I want to use temperature dependent viscosity in my model.
Thank and Regards
QaisKhraisat likes this.
Mayank Shakya is offline   Reply With Quote
Old   August 18, 2022, 08:34
Qais
Make sure you specify the units at the end only. This is the formula that I wrote:
((10^(10^(n-(m*(log(T*1[K^-1]))))))-a)*(1000)*(10^-6) [Pa s]
In the formula (n, m , a) are constants. T represents the temerature, but notice that I added (k^-1) to make it a dimensionless value. At the very end, I specify the unit which is (Pa s)
BE CAUTIOUS with the UNITS in your case.
Hope this was helpful.
Qais Khraisat
Mayank Shakya likes this.
Old   August 18, 2022, 14:52
Mayank Shakya
Thank you very much the problem is solved.
Do you know how I can calculate Frictional Torque in Hydrodynamic Thrust Pad Bearing.
Old   August 18, 2022, 19:39
Use the CEL expressions like torque_x(), torque_y() etc on the boundary face which is the face you want the torque from.
Old   August 20, 2022, 12:50
Mayank Shakya
Hello
Thank you very much I got all the problem solved.
UDF to Define Temperature Dependent Negative Heat Source ATIKADAR Fluent UDF and Scheme Programming 1 September 23, 2019 04:52
Temperature dependent viscosity (Carreau-Yasuda) open OpenFOAM Programming & Development 3 June 21, 2016 09:35
Problems in converging viscosity UDF dependent upon strain rate and temperature. alexskerhut Fluent UDF and Scheme Programming 1 March 17, 2016 08:19
OpenFOAM solver for incompressible BUT temperature dependent flow niko0807 OpenFOAM Running, Solving & CFD 2 October 27, 2015 06:31
Temperature dependent Non-Newtonian viscosity UDF cric92 Fluent UDF and Scheme Programming 0 April 14, 2013 07:31
