May 3, 2007, 09:30 |
BladeGen documents
Dear all, I am learning to use CFX to solve the flow across the wind turbine. With the softwares I have, I decided to use BladeGen to construct the geometry, then use TurboGrid to generate grid, and use CFX to solve the flow. However now I stucked with BladeGen. I have problems to understand BladeGen's help files. Do you have any suggestion? Thank you very much for your kind consideration.
Atit |
May 3, 2007, 15:13 |
Re: BladeGen documents
I am also trying do so on a centrifugal compressor. I also got stuck and don't have the help files installed for some reason. My problem is to analyse the rotor-stator interaction. I could not sucessfully create the rotor and stator. But, suppose I can create them, I am not able to understand, how do I integate the rotor (or rotor mesh) and stator( or stator mesh)? Does it need to be done in BladeGen or in TurboGrid.? If possible please forward the help files to my e-mail address, I will try to see if I can make something out of it.
Thanks, Dip |
May 5, 2007, 08:02 |
The BladeGen help documentation is terrible. If you are stuck you are not likely to get an answer though the help doc.
May 5, 2007, 08:03 |
BladeGen creates the geometry, TurboGrid meshes the geometry. You cannot create multiple stages in BladeGen. Create your rotor and stator geometries and meshes separately, and import the meshes separately into CFX Pre.
May 5, 2007, 11:13 |
Yes, BladeGen documentation is not good, but it is usable. The only additional documentation was presentation in german... that I saw one time. But I had training... But most infomation I got from help.
May 6, 2007, 02:20 |
BladeGen documents
Bladegen uses the theory from a chinese scintist to define the Blades meridional profile and other profiles.First u must have some knowledge about the blade profiles,aerofoil shapes,search on net for this.Then bladegen have some example files in the root directory,refer their profiles. Convert your xyz cordinates to rtz cordinates.use rz in meridional profile and theta in angle definitions,play with it and observe the changes in 3D profile,can give u some clues.
May 6, 2007, 13:54 |
To try using BladeGen, I have three questions as follows:
1. I'd like to verify my modeling ability by simulating the NREL Phase II wind turbine which I have the experimental results, but I do not understand some terms. In the 'Basic Machine Parameters' section, it specifies that ================================ - Type of rotor: fixed - Tilt: 1 degree (blade pitch angle was calibrated assuming 0 degree tilt) - Cone angle: 3.417 angle ================================ My first question is what this 'tilt' mean? and what is the 'fixed rotor'? 2.In BladeGen, what do 'M-Prime', 'Theta-Prime', 'Blade Lean Angle', and 'Beta' mean? 3. The blade pitch is set to 12 degree. In BladeGen, what is this? Theta or Beta? Thank you very much for your consideration |
May 7, 2007, 00:59 |
Mr.Atit,What u want is very specific. But as concerned to Bladegen,all the definitions are for the Meridional Profile i.e from leading edge of a Blade to its trailing edge following the root of meanline(Centreline)where % M is Meridional fraction,simillarly in help glossary u will find what is M-prime or other things,these r all blade related definitions,u can search them in any aerofoil or turbine related books.About theta-which is one of the cordinate of r-theta-z cordinate system,which is square root of x2+y2,2is for square.Beta is Blade angle,right click in angle definition,go to angle definition and u can change it.
September 27, 2013, 22:42 |
#9 |
Ahmad
Rep Power: 13 |
Can any one tell me how I can change Blade pitch of axial flow turbine in BLADGEN.I searched alot but failed to get answer.PLZ HELP.
April 21, 2015, 10:14 |
#10 |
Umair
Rep Power: 11 |
anyone can tell me how to determine the Leading wedge angle or Trailing wedge angle of turbine blade in Ansys Bladegen or any relation plz share with me.
February 23, 2016, 07:41 |
#11 |
ashwani
Rep Power: 11 |
Hi Guys,
Can anyone share the help files or tutorials of blade gen Please.... When I try to open the help files in blage gen, it says "Failed to launch help" and opens a Microsoft support page, which again does not solve the issue". Any help will be highly appreciated. Thank You. Email id: ashwani.thakur321@gmail.com |
February 23, 2016, 11:30 |
#12 |
Rep Power: 17 |
Ansys BladeGen (previously CFX-BladeGenPlus) is quite self-explanatory. Ask whatever you want to know.
February 26, 2016, 07:38 |
#13 |
Stephan Hötzl
I have created stator blades (guide vanes) for an axial turbine and so far everything looks fine. Turbogrid produces a nice mesh.
In the next step I would like to create meshes with different opening angles of the guide vanes. They will be adjustable in the actual turbine aswell. When I use the "setup blade rotation" and "rotate blades about Axes" tools I can achieve what I want, but unfortunately the blade profile gets distorted. Is there anything I can do about that? |
February 26, 2016, 08:12 |
#14 |
Rep Power: 17 |
Advanced question.
I do have some doubt about the function though I did not check the rotated blade geometry in details. From my visual check, it looked OK in my case of a symmetrical inlet guide vane. Upstream and downstream flowpath look curved, but in Turbogrid they turned out normal. From 90 deg down to 20 deg opening, I had no big issues. If you see some issues in your stator, I would export the meanline file (.rtzt) to be imported into a small custom program (fortran). Rotaing xyz coordinates are easy to build in your program, and then spits out the new .rtzt for BG to import again. |
February 26, 2016, 10:01 |
#15 |
ashwani
Rep Power: 11 |
Can anyone suggest some good resource to learn about the various geometric planes (like meridonial and blade to blade plane) and other views that are presented in the Blade gen. I am just starting blade gen and does not have any basic understanding of the geometry of blades.
Thanks. |
February 26, 2016, 10:20 |
#16 | |
Rep Power: 17 |
April 2, 2016, 07:18 |
#17 | |
ashwani
Rep Power: 11 |
Can any one guide me as to how calculate the Warp angle(theta) and flow angles(beta) at LE and TE from the airfoil data points or shape calculated through CMM. As I need to enter these angle values in BladeGen. Thanks. |
April 3, 2016, 22:37 |
#18 |
Rep Power: 17 |
Theta = theta in the cylindrical coordinate system
Flow angle is not to be mentioned here. It should be Blade angle. Blade angle (Beta) is the angle defined on the m-(r*theta) plane. As I said, you will need to read turbomachinery introduction books. |
May 18, 2016, 04:48 |
Bladegen export
#19 |
mohsen rahmani
Rep Power: 12 |
does anyone know when we export Turbogrid file from bladegen the points of profile.curv is xyz or rtz?
March 9, 2017, 02:35 |
#20 |
Behnam st
can you suggest any source for learning blade gen??
BladeGen problem | David Wang | CFX | 5 | April 2, 2016 06:18 |
[TGrid] Bladegen w/o turbogrid | Biskvito | ANSYS Meshing & Geometry | 5 | September 6, 2011 09:13 |
BladeGen and CFX - basic question | Dip | CFX | 5 | August 5, 2010 18:21 |
BladeGen to Geometry file | sriram | CFX | 0 | January 4, 2009 03:36 |
DOCUMENTS EXTERNAL AERODYNAMICS | Erdem | FLUENT | 0 | March 2, 2006 06:03 |
