April 25, 2007, 12:20 |
ansys
Hi, I have a big problem, I have to calculate drag force on a sphere in a duct using ansys 10, but intsrf, tauw result 0...so I cannot calculate it. code is the following...someone help me!! Please
/NOPR ! Suppress printing of UNDO process /PMACRO ! Echo following commands to log FINISH ! Make sure we are at BEGIN level /CLEAR,NOSTART ! Clear model since no SAVE found ! WE SUGGEST YOU REMOVE THIS LINE AND THE FOLLOWING STARTUP LINES /input,start100,ans,'C:\Archivos de programa\Ansys Inc\v100\ANSYS\apdl\',,,,,,,,,,,,,,,,1 /REPLOT,RESIZE /NOPR /PMETH,OFF,0 /FILNAME,2d_sim,0 KEYW,PR_CFD,1 !units in micron /units,si,10^-6 /PREP7 nts = 40 ! number of time steps time =2 ! total simulation time delta = time/nts RHO = 1000 ! Fluid density MU = 0.001 ! Fluid viscosity ET,1,FLUID141 RECTNG,-700,-25,1,50 RECTNG,-25,25,1,50 RECTNG,25,700,1,50 RECTNG,-25,25,0,1 CYL4,0,0.5,0.1, asba,4,5 aglue,all alls !meshing lsel,s,,,1,3,2 lesize,all,1,,,1 alls lsel,s,,,2,4,2 lesize,all,1,,,-4 alls amesh,1 lsel,s,,,21,22 lesize,all,1,,,1 alls lsel,s,,,2,6,4 lesize,all,1,,,-4 alls amesh,4 alls lsel,s,,,23,24 lesize,all,1,,,1 alls lsel,s,,,6,10,4 lesize,all,1,,,-4 alls amesh,5 SMRT,1 MSHAPE,1,2D MSHKEY,0 amesh,7 AREFINE,7, , ,1,0,1,1 !boundary conditions DL,10, ,PRES,0,1 DL,1, ,VY,0,1 DL,3, ,VY,0,1 DL,22, ,VY,0,1 DL,24, ,VY,0,1 DL,23, ,VY,0,1 DL,26, ,VY,0,1 DL,13, ,VY,0,1 DL,25, ,VY,0,1 DL,4, ,vx,0.031e-3 /SOL /del,2d_sim,rfl FLDATA1,SOLU,TRAN,1 FLDATA1,SOLU,FLOW,1 FLDATA1,SOLU,TURB,1 FLDATA1,SOLU,RDSF,1 FLDATA7,PROT,DENS,CONSTANT FLDATA8,NOMI,DENS,RHO, FLDATA7,PROT,VISC,CONSTANT FLDATA8,NOMI,VISC,MU FLDATA12,PROP,IVIS FLDATA7,PROT,COND,CONSTANT FLDATA8,NOMI,COND,-1, FLDATA7,PROT,SPHT,CONSTANT FLDATA8,NOMI,SPHT,-1, FLDATA5,OUTP,PTOT,1 FLDATA5,OUTP,STRM,1 FLDATA5,OUTP,TAUW,1 flda,time,step,delta flda,time,numb,nts flda,time,tend,time solve /POST1 SET,LAST PLVECT,V, , , ,VECT,ELEM,ON,0 !calculo promedio velocidad lsel,s,,,17,20,1 lplot nsll,s,1 nplot !average velocity vel_x=0 vel_y=0 *get,n_nod,node,0,count *dim,velo_nod,table,n_nod,3 *do,_l,1,n_nod,1 *get,pnn,node,0,num,min *set,velo_nod(_l,0),pnn *GET,velo_nod(_l,1),NODE,pnn,V,X *GET,xxx,NODE,pnn,V,X vel_x=vel_x+xxx *GET,velo_nod(_l,2),NODE,pnn,V,y *GET,yyy,NODE,pnn,V,y vel_y=vel_y+yyy *GET,velo_nod(_l,3),NODE,pnn,v,sum nsel,u,node,,pnn,pnn,1 *ENDDO vel_x=vel_x/n_nod vel_y=vel_y/n_nod alls !average velocity to calcule drag force LOCAL,11,0,-0.1,0.5,0, , , ,1,1, CSYS,11, intsrf,tauw *get,forcex,intsrf,0,item,fx *get,forcey,intsrf,0,item,fy *get,forcez,intsrf,0,item,fz *get,momx,intsrf,0,item,mx *get,momy,intsrf,0,item,my *get,momz,intsrf,0,item,mz !!I'd like to know drag force on sphere..result is 0!! |
April 25, 2007, 15:49 |
Re: ansys
well I have to admit, I cannot really follow your script (and I guess it's not about the script itself, I just do not understand it) but the typical problem (no offense) is to try to get the drag all over the surface, not only in the projection of the plane perpendicular to the flow direction IN ONE direction.
just a guess. matej |
Command Line Run for ANSYS | Liaquat | ANSYS | 11 | April 19, 2018 10:49 |
Running Ansys in BAtch Mode | kuleuvenstudent | ANSYS | 1 | October 18, 2017 13:11 |
Fluid structure interaction | jnattia | Main CFD Forum | 25 | May 21, 2015 10:16 |
Ansys workbench problem | Jonny6001 | ANSYS | 2 | September 30, 2010 13:59 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 02:10 |
