October 9, 2021, 13:27 |
Unable to make groove-shroud interface
Jason Bavosky
Rep Power: 5 |
I am trying to study of effect of types of groove casing on performance of axial compressor, in my case - Rotor 67. Fortunately, I found a video on this case and I've been following it. The problem is I am not able to make an interface between shroud and groove inlet as the video demonstrates at 12:20. Here's the video link - https://youtu.be/HeVdLJTBKxM While box selecting the area, only the outer part OR border gets captured unlike the video in which the whole rectangular area(groove inlet) gets selected. Please have a look at the attached image. I also tried by changing selection tool - Fully enclosed and Touching and enclosed. Didn't work. Does anyone know where am I going wrong? Thanks |
November 4, 2021, 02:08 |
Jason Bavosky
Rep Power: 5 |
Hello.. Anyone? Any insight?
I'm running out of time and still am stuck here! Thanks! |
November 4, 2021, 05:53 |
Rep Power: 144 |
Have you tried defining the faces as named selections? If that is possible then it is easy to select them.
Alternately you can use the face selection tool to select the face. You might need to run through a long list of faces until you find the right one, but it should be in the list somewhere.
axial compress rotor, cfx, interface |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
