turbulence in a pipe
Old   April 19, 2007, 22:56
Default turbulence in a pipe
kang
I am doing turbulence of a pipe now, but I have got two problems in meshing. the pipe is one-meter-long with the diameter of 50cm. the mesher sent the warning message 'aspect ratio >50',and I tried to reduce the default face spacing,but no improvement. and then I tried to add wall as face spacing.but still I got this warnig . Another thing is about the inflation layers,I set it for 30,but I am not sure.Can somebody please give me a hand? many thanks.
Old   April 22, 2007, 19:40
Default Re: turbulence in a pipe
If the aspect ratio warning applies to the inflation layers then you can probably ignore it. If the elements are aligned with the flow (and with nice inflation layers it is) you can still get accurate results with quite high aspect ratios.
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
