Heat Flux in the Near-Wall Region
Old   April 16, 2007, 13:34
Default Heat Flux in the Near-Wall Region
Malcolm
Does CFX have a 'switch' to activate the Heat Flux in the Near-Wall Region or do you have to code the equations described in the solver theory yourself?
Thanks
Old   April 16, 2007, 18:19
Default Re: Heat Flux in the Near-Wall Region
Opaque
Dear Malcom,
Are you referring to the turbulent wall function boundary condition closure for the energy equation?
The equations are already in the code, and are active when you select a turbulence model.
Why do you think that you should code the equations separately?
Opaque.
Old   April 16, 2007, 19:12
Malcolm
I'm referring to equation 187 of the CFX-Solver 10.0 Theory where qwall = ((rho x Cp x u*) / (T+)) x (Twall - Tfluid), i.e. the wall heat flux model that approximates a heat transfer coefficient.
Thanks
Old   April 16, 2007, 19:22
That equation is automatically used when you select a simulation with a thermal field and a wall boundary condition which will result in heat transfer (ie not adiabatic).
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Need Help on Heat Flux Profile within Pipe Wall mep10jl FLUENT 3 June 6, 2011 18:08
groovyBC nonuniform Wall heat flux Shoonya Main CFD Forum 0 August 11, 2010 14:03
wall heat flux Sangeeta FLUENT 0 May 7, 2009 03:22
WALL HEAT FLUX V.S. HEAT FLUX tommy CFX 0 December 15, 2005 09:14
