How to keep y+ below 1
Old   September 20, 2021, 16:05
Talking How to keep y+ below 1
Mohamed911 is on a distinguished road
Hello everyone.
I'm working on an axial pump. in literature, they recommend that y+ should be kept below 1.
how do I keep y+ below 1?
note that I'm using TurboGrid for meshing, and I'm using K-epsilon as a Turbulence model
Mohamed911 is offline   Reply With Quote
Old   September 20, 2021, 17:32
Opaque will become famous soon enough
Confused..
Why would you want to keep y+ ~ 1, and then use k-epsilon? The point of using k-epsilon is to be able to use coarser meshes and rely on the wall function to cover for the mesh deficiencies.
k-epsilon on wall resolved meshes is a waste of computer resources with no increase in accuracy
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   September 21, 2021, 03:43
karachun's Avatar
karachun is on a distinguished road
When using k-e model with small y+ values you can even broke your solution so yeu gen nonphysical solution.
karachun is offline   Reply With Quote
Old   September 21, 2021, 07:37
Originally Posted by Opaque View Post
Confused..
so in your opinion. which turbulence model would be better to use?
Note: I am studying the induced shear stress
Old   September 21, 2021, 11:22
siw
Stuart
siw will become famous soon enough
I recommend you read these CFD Leap Australia blogs articles hyperlinked in my post (2nd in thread).
CFX SST model with wall function and yplus
Better yet is someone sticks theses useful resources at the top of the CFX forum.
siw is offline   Reply With Quote
Old   September 21, 2021, 19:02
Yes, the SST turbulence model is the best model for most applications for CFX. It is definitely the most widely applicable across a large range of flow types, as it has sub-models for integration to the wall, rotating flow corrections, laminar to turbulent transitions, high mach number corrections, wall roughness models, ability to link to LES style models and more.
Old   September 21, 2021, 20:33
Gert-Jan
Gert-Jan will become famous soon enough
SST is now the default turbulence model in Fluent.
I don't know why it isn't in CFX yet.
For reasons Glenn just mentioned, it should be upgraded to the default in my opinion.
Gert-Jan is offline   Reply With Quote
Old   September 22, 2021, 05:14
I tried to do simulations with what you suggested (SST).
for the mesh, I used TurboGrid as the mesh tool. a wall function Y + = 1 with 30 layers. the Reynolds numbers were set at 1E-05 for the stationary parts and 1E-06 for the rotor.
however, the results show that Y + is greater than 10
Old   September 22, 2021, 06:52
Gert-Jan
Then reduce the first layer thickness such that your Y+ becomes below 1.
Old   September 23, 2021, 13:21
I tried to do this. but I couldn't find how to modify the layer thickness in TurboGrid.
all I could get is "Layer offset" and "wall Y+".
k-epsilon model, turbogrid y+
