How can i get the normal and shear force on a wall?
Old   September 5, 2021, 17:30
Post How can i get the normal and shear force on a wall?
xiasheng
xiasheng is on a distinguished road
hello, i am doing a 2D calculation result in the cfx.
I try to get the lift force and component of a cylinder.
lift force is easy, i use force_y@cylinder because flow direction is jast to X.
but i have problem of component, i want get force from normal pressure force and shear viscous force.
at first, i use theta=atan2(Y-0.005[m],X-0.81[m]) to get the agree of point on the cylinder,[0.81 0.005]is the center of cylinder.
for normal pressure force, i use areaInt(p*sin(theta))@cylinder to get it
for shear viscous force, i use areaInt(Wall Shear*cos(theta))@cylinder
in theroy, lift force=normal pressure force+shear viscous force, but i got (normal pressure force+shear viscous force) bigger than 3xlift force
i have checked fluent and it show me same lift force.
so i think some error about normal pressure force and shear viscous force
can some on help me? and if it is unscrupulous object, how can i get component of lift force?
xiasheng is offline   Reply With Quote
Old   September 5, 2021, 18:51
Have you plotted the the theta function and checked it is correct? Also check the p*sin(theta) and Wall Shear*cos(theta) components are correct?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Calculation of Wall Shear Stress Dave442 CFX 36 July 12, 2016 05:12
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
impact force (shear stress) by waterjet impingement herozhu Main CFD Forum 0 May 7, 2014 21:39
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
Wall shear forces philippose OpenFOAM Running, Solving & CFD 0 April 29, 2007 11:10
