Enable Particle User Routine in Multiphase Reactions
Old   August 28, 2021, 16:01
Question Enable Particle User Routine in Multiphase Reactions
rxxxrxxx is on a distinguished road
I want to recreate a simulation with particle user routine enabled as a beta feature, more specifically I want to have this [Outline->Simulation->Reactions->Multiphase Reactions->Multiphase Reaction Rate->Option = Particle User Routine] enabled.
My approach: First i add a reaction under [Outline->Simulation->Reactions], then i double click on it and set [Basic Setting->Option = Multiphase], then in [Multiphase Reactions->Multiphase Reaction Rate->Option] I could not find "Particle User Routine" as a valid option.
I must have missed some setting for that beta feature, could someone please help me out here?
Much thanks in advance!
rxxxrxxx is offline   Reply With Quote
Old   August 28, 2021, 16:16
Turns out I have to check "Enable Beta Features" in [Edit->Options->CFX-Pre->General->Beta Options], then the "Particle User Routine" option magically appears...
beta feature, multiphase reactions, particle user routine
particle surface reactions rati FLUENT 2 July 26, 2020 10:31
How to make user routine just be called once in one time step? doublestrong CFX 3 October 22, 2018 00:06
Particle temperature setting with heat source routine amd18 CFX 0 June 24, 2017 13:24
calculate particle temperature gradient with user routine amd18 CFX 1 April 3, 2017 12:32
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
