CFX11.0 cannot find dll in User Fortran
Old   April 4, 2007, 11:42
Default CFX11.0 cannot find dll in User Fortran
brunoc
Hi there,
I keep getting the error above when running a simulation that has some User Fortran routines:
| Subsystem: Input | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |---------------------------------------------------| | Message: | | | | Error opening E:\ThermalResist\winnt\cts.dll: The | | specified module could not be found. |
And then, since the library was not found:
| Subsystem: Input | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |---------------------------------------------------| | Message: | | | | USER ROUTINE: writevar could not be loaded. Pleas-| | e check the Library Path, Library Name and Callin-| | g Name. For FORTRAN user routines, the Calling Na-| | me should be in lower case. |
First, the file IS there. In other words, the path is correct. The path used to define functions within Pre is also correct, that is, it points to folder 'E:\ThermalResist'.
I've checked permissions, and that is not a problem either.
Calling Names are all in lower case.
I've had this problem several times, and I don't know why the Solver can't find the file. Did anyone have this problem?
Thanks in advanve, Bruno
Importing external DLL to Ansys CFX using user Fortran snpradeep CFX 2 May 16, 2014 04:52
Comparison between C/C++ and Fortran? rick Main CFD Forum 45 September 6, 2011 01:52
fortran dll ollimarc CFX 3 October 19, 2010 15:26
CFX 12.0, user fortran error songxguan CFX 3 December 23, 2009 16:24
user fortran: boundary conditions-transient simula Vanessa CFX 0 October 20, 2005 10:23
