March 26, 2007, 13:24 |
Negative drag on a yacht Sail section
Hi
I am running a simulation of a 2D sail section. (essentially half an airfoil with a cylinder at the leading edge) The strange problem I have is that when I use the 'force calculator' in Post I get a negative drag value on the mast. Interestingly if I simply reverse the sign on this value I get roughly reasonable results compared with experimental data. The sail itself gives results with the expected signs. The pressure distribution looks correct on the mast i.e. it should be giving a posistive drag value. I notice from one of your posts that people have had problems with the 'force calcultor' before. Could someone advise if they have come accross a similar problem? Many thanks Iain P.S. I have checked the surface normals are all consistent. |
March 27, 2007, 08:19 |
Re: Negative drag on a yacht Sail section
This is most likely a simple definition "error" i.e. whether the force is shown IRO the fluid domain vs. the adjacent solid domain.
March 27, 2007, 09:02 |
Thanks Joe
I agree this seems to be the likely cause. I apologise but I am a relatively new user to CFX and am unsure how I can control whether the force is w.r.t the solid or fluid. Is it possible I have the sail and mast on opposite settings? (As I said before I have aligned all the surface normals, which was my first thought) Many thanks for your patience |
March 27, 2007, 09:06 |
I am running ICEM and CFX-10.
Thanks again |
Airfoil negative drag coefficent | James Forrest | Main CFD Forum | 9 | September 5, 2022 10:30 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
