Rep Power: 0 ![]() |
Hi guys,
I'm struggling with an maybe easily to solve problem but I just can't manage to do so. I'd like to use a previously simulated pressurefield as a boundary condition on one of my outlets. Therefore I imported the .csv file of my simulation. So far it works fine. The imported pressure field has periodic boundaries so in theory I should be able to stack it in my case in y-direction. I do need to do this since my Outlet I need the pressure field for lies in the intersection of 2 of these fields. Now I'm struggling to double my pressure field. I found the "edit profile data" option but this just helps me to move the field around or to do an expansion which sounds like it's exactly what I want but it just copies the field around an axis in a circular way. I need it doubled but translatorical. Any ideas on how to solve this? Hope you get my problem and I didn't describe it too poorly. Thanks in advance! John |
#2 | |
Kira
Rep Power: 8 ![]() |
Thanks for your help @aero_head! But I found a solution in the meantime. I just manipulated the .csv-file in excel. Had problems with opening the file in excel because of regional settings in windows that created problems with list seperation but everything fixed now.
Have a nice day! ![]() |
cfxpre, csv files, pre-cfx, profile boundary cond., profile data |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 03:52 |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
