August 23, 2021, 00:22 |
#21 | |
Rep Power: 13 |
I have tried multiple cases with a fine mesh and 5-7 layers at the interface, double precision solver, high resolution advective scheme for this variable, and still have a distribution of the Residence time at the fresh flow region. The only thing that comes to my mind is that since the flow is inherently diffusive, in addition to be advective, therefore, we observe the influence of the recirculation flow at the boundary of the fresh incoming flow. At the center of the fresh flow, the residence time is zero. Therefore, observing a distribution of residence time at the boundary of the fresh incoming flow seems unavoidable, although it is very small, i.e. <0.02 s. In different note, I would like to acknowledge your advice in my future publication and would like to have your affiliation. Thank you, Mehdi |
August 23, 2021, 01:02 |
#22 |
Rep Power: 144 |
Good to hear you got it working good enough in the end.
My name is Glenn Horrocks, I work for Memjet Australia.
areaint, cfx, flow rate |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 10:17 |
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate | MSchneid | Fluent UDF and Scheme Programming | 3 | February 23, 2019 07:00 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
UDF to access interior surface to calculate mass flow rate | shahjehan | Fluent UDF and Scheme Programming | 0 | August 11, 2015 15:44 |
mass flow in a specified surface | lenson | Siemens | 4 | January 27, 2005 10:45 |
