Rotation on linear cascade turbine
Old   July 29, 2021, 18:17
Default Rotation on linear cascade turbine
Gennaro Desiderio
gendes is on a distinguished road
Dear people,
I am a Master student and I am using CFX for my Master Thesis. Actually I have some problems and I hope someone could help me.
My profile is a turbine blade from a cascade and I have to simulate the effects of an eventual rotation. I am applying a linear velocity (computed as omega*r) in -Y but it doesn't work on the lateral sides (they are an interface with translational periodicity + nonoverlap condition for imposing the velocity).
From the post processing I can see the velocity vectors, and I have no problems with airfoil, upper wall and lower wall, but with interfaces. How can apply a linear velocity on a stationary profile?
Moreover, for replacing the centrifugal force, I was thinking to apply bouyancy along +Z.
(Ansys CFX 18.0)
What to you think? Have you got any suggestions for me? What about the Coriolis force?
Thank you in advance to everyone
gendes is offline   Reply With Quote
Old   July 29, 2021, 18:52
Opaque will become famous soon enough
You must locate the passage away from an axis, and use Rotational Periodicity.
Since the Rmax/Rmin ~ 1, the solution is effectively the linear cascade solution
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   July 29, 2021, 19:35
Gennaro Desiderio
Thank you Opaque,
I tried to apply a rotation with rotational periodicity but the simuation collapses, and I think is for the linear design of the model
Old   July 30, 2021, 10:03
Have seen the approach used ten of times. The problem is elsewhere.
Start small,
1 - Set it up with angular velocity = 0
2 - Increase the value and see if your setup makes sense
3 - Approach the intended velocity
Old   July 30, 2021, 12:20
Gennaro Desiderio
Thank you.
But what if I would maintain the linear approch? How could I simulate the rotation effect, applying a linear velocity, as tangential one, computed as omega*r? And at this point, how could I simulate coriolis and Crentrifugal acceleration?
Old   July 30, 2021, 14:11
If you want to go with the linear approach, you must write your mathematical model for a non-inertial frame, then identify the missing terms in the equations compared to the default model.
Those missing terms can be added as sources using sub-domains.
If you have a single cascade, there should be no issue with sliding interfaces and you should be good.
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Turbine Free Rotation Option zacko CFX 8 February 7, 2017 03:15
[ANSYS Meshing] Wind turbine rotation goral04 ANSYS Meshing & Geometry 0 May 5, 2016 10:20
error on turbulence scheme immortality OpenFOAM Pre-Processing 11 August 21, 2013 09:45
Rotation of Blade in steam turbine ramu maddi CFX 0 September 10, 2008 06:15
