CFX Fluid Domain Movement
Old   March 21, 2007, 13:34
Default CFX Fluid Domain Movement
greg
I'm performing a conjugate heat transfer analysis in CFX with a fluid and solid. I would like to perform a transient analysis where the fluid domain moves over the solid domain at a constant velocity. Is there a way to do this in CFX? Any help is greatly appreciated.
thanks, greg
Old   March 25, 2007, 09:08
Default Re: CFX Fluid Domain Movement
Prashanth
Can you be more spefic about what you mean by fluid domain and solid domain? Their shapes? If you want to do moving boundary analysis, you have to apply the transient boundary conditions by defining functions in CFX. I think this is what you have to do for your fluid domain now.
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? acro CFX 15 September 23, 2016 12:16
Constant flow rate through a small area inside the fluid domain. robingilbert OpenFOAM 7 October 4, 2010 17:19
ERROR #001100279 for a Rotating Fluid Domain Fonzie CFX 3 August 24, 2010 20:42
Theory behind the solid domain rotation in fluid using Bets property Riken CFX 0 October 28, 2009 10:51
Fluid - Solid Domain Interface Daniel CFX 6 February 15, 2009 19:09
