July 6, 2021, 02:44 |
Jet simulation on a rotating disk
Ali zadehkafi
I want to simulate a rotational disk in cfx which is affected by an imping jet.
My simulation is transient. I have two domains: a fluid domain that is stationary and a rotational solid domain. I want to plot average disk temprature versus time. these two domains have a transeint rotor stator interface. my results are incorrect. would you please recommend how to simulate this issue? Boundary conditions and two domains are shown in the attached image. |
July 6, 2021, 04:08 |
Uwe Pilz
Rep Power: 15 |
I recommend splitting the simulation.
At first make a fluid only simulation, without the temperature field. As far as I understand your case, this should be possible with only one region, which is far easier to stabilize. From this simulation calculate the thickness of the Prandtl layer. With this Prandtl layer make a temperature only simulation, which is in fact some type of diffusion. That is not a problematic case.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
rhoCentralFoam Negative initial temperature in simulation of gas jet into vacuum | c_underwood | OpenFOAM Running, Solving & CFD | 1 | November 19, 2020 15:45 |
How to set up transient simulation for rotating parts | rusham | FLUENT | 2 | July 28, 2017 06:58 |
Jet engine simulation | alepal | CFX | 4 | May 27, 2015 07:40 |
2D LES simulation of turbulent jet | adnan.nweilati | FLUENT | 6 | December 3, 2014 10:33 |
problems in synthetic jet flow simulation | jackxu | FLUENT | 0 | December 2, 2012 10:12 |
