Convergence issue
Old   March 4, 2007, 15:07
Default Convergence issue
Omer
I have a model of a straight pipe, I am using to get a fully developed profile to use in my pipe junction.
I am using an SST model. Funnily, I seem to have no convergence even after about plenty of iterations. The behaviour is bouncy but it does not even try to go down even a tiny bit.
I tried playing with the timestep. But that didn't work.
But funnily enough, when I refine the mesh, I get convergence as low as E-12 in just 5 iterations. So what can my problem be?
I use CFX mesh to create the mesh. While trying to keep the Y+ less than 1.
Thanking in anticipation
Old   March 4, 2007, 18:41
Default Re: Convergence issue
Astrid
Something is really very wrong when you get convergence to 1e-12 in 5 iterations. This cannot be a converged solution!
When you use SST and find a lot of flow separation at delicate locations you won't ever get convergence. Have you exported residual values to your res-file? What do these tell you?
Have you tried k-e with scalable wall functions? This should converge quite fast as it clips to y+=11.
What do you define on the in- and outlet in terms of turbulence?
Astrid
Old   March 7, 2007, 11:37
Omer
Well, my inlet velocity is 210 m/s. I did a little calculation for my branch of diameter- 16 inches. And found out that the trubulence intensity would be around 2.3%.
My outlet is a pressure out, at 0 atm. I will try to see how K-epsilon does.
Have I exported residual values to your res-file? I am not really sure what that is, and how it may help? Would you please help me understand?
Thanx for replying Astrid!
Convergence issue with continuity equation Jake FLUENT 8 June 6, 2018 04:41
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
Convergence issue in SST for Porous model Raj CFX 0 May 2, 2008 03:43
CFX-Solver, issue with convergence behavior Andy CFX 7 September 5, 2006 04:24
