how to link a C program to ANSYS CFX ?
Old   June 16, 2021, 07:29
Question how to link a C program to ANSYS CFX ?
Mohamed911 is on a distinguished road
I am currently working on an axial pump. The original geometry didn't perform as well as I expected, so I plan to improve its performance. But all the ANSYS tools I tried either didn't work or didn't give me control over the variables I wanted, so I decided to use C code.
Is there any way to link the C code to Ansys CFX?
Thank you very much.
Mohamed911 is offline   Reply With Quote
Old   June 16, 2021, 07:54
That depends on what you are trying to do. CFX has a C++ interface for reading and writing meshes. The solver has a user fortran interface, and the whole thing can be scripted using various text files (session files, CCL etc) so you can automate CFX by writing these text files. Writing text files can be done in just about any language.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   June 16, 2021, 08:38
first, the pump parts are made using Bladegen, then imported to Turbogrid for meshing, after that setup, and CFD-post.
I'm using genetic algorithms, so all the process should be done automatically
Old   June 16, 2021, 08:42
In that case it sounds like you want to write something which generates the input command files for Turbogrid, CFX-Pre, Solver and CFD-Post and then calls the command line to start those packages. This can be done in C or just about any other language. It is just generating text files and then running executables from the command line.
c programming, cfx 18, optimization parallel
Ansys Installation on Docker Container mohsen.shiea ANSYS 11 March 14, 2024 12:18
Compressible Flow in Ansys CFX bcheruk CFX 15 July 6, 2017 07:30
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
ICEM of ANSYS V15: how to export .msh mesh for CFX hydroaero ANSYS 1 March 9, 2015 23:17
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
