February 23, 2007, 02:31 |
which model is suitable?
Dear Friends,
In CFX, which model is better for calculate high speed(M =1), compressible air? K-e model?? Thank you in advance. Eric |
February 23, 2007, 08:05 |
Re: which model is suitable?
SST
February 23, 2007, 08:28 |
Thank you.
And which is better, upwind or high resolution? Thank you in advance |
February 23, 2007, 10:09 |
Hi Eric,
about upwind: it is more robust, needs less computaional time and is less accurate... on the other hand, about high resolution: it is less robust, needs more computaional time, is more accurate and also need finer grid size... so, you have to decide, which on fits to your problem more!! Best regards, houman |
February 23, 2007, 10:11 |
Many Thanks
February 23, 2007, 10:20 |
Just the opposite: high res, being more accurate (mostly second order rather than first order), actually requires a less fine mesh than upwind in order to achieve a mesh-independent solution.
High res is also (generally) quite robust - it is the default! In general, avoid upwind. |
February 24, 2007, 07:01 |
I agree with Phil. Only use upwind to get a solution started. Always switch to high res for final solution.
February 24, 2007, 10:24 |
Johnny is right
February 27, 2007, 18:48 |
#9 |
Upwind = You are more likely to get a "conservation satisfying" answer but it is wrong.
Integration of a Custom C++ Model into FLUENT | Syed Haider | FLUENT | 2 | March 7, 2018 00:37 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 14:57 |
species transport model or mixture model? | achaokaoyan | Main CFD Forum | 0 | July 10, 2010 11:52 |
multi fluid mixture model issue | rystokes | CFX | 3 | August 9, 2009 20:13 |
