February 20, 2007, 10:07 |
Rotating mesh
Hey CFX-users.
I have the following question: Is it possible to rotate a mesh in CFX, when the mesh is a structured mesh created in ICEM? And if so, do you have a pointer of how to do this, or where to find info about this function? I know how to create a moving mesh in translation, so this is not the problem in hand. And my profil is not to be moved. Thanks in advance... Regards Jesper |
February 20, 2007, 16:53 |
Re: Rotating mesh
The solver does not care where the mesh comes from. The moving mesh function will work the same on meshes from any meshing package. So to answer your question, yes a structured mesh can be used in a rotating domain. Glenn Horrocks |
February 21, 2007, 03:32 |
Re: Rotating mesh
Hi again
thanks for that response. But my question still stands: How to do a rotating mesh or where to read about the procedure? (and with out having to large mesh deformations) tanks again Jesper |
February 21, 2007, 09:01 |
Re: Rotating mesh
If you have a rotor/stator problem then the frozen rotor concept might be the right for you. That's also the way to do a simple steady state simulation.
February 21, 2007, 10:03 |
Re: Rotating mesh
Im not sure I 100% understand that reply...
I hav a bridge profile centered in a 2D Windtunnel (one element thick), and want to rotate the mesh around the profile. How to do this? sorry if it was not clear enough at first. Regards Jesper |
February 21, 2007, 17:11 |
Re: Rotating mesh
Hi Jesper,
What are you trying to do? Why do you want to rotate the mesh around the profile? Glenn Horrocks |
February 22, 2007, 05:19 |
Re: Rotating mesh
Then forget about the frozen rotor concept. But I also don't understand your problem. Maybe you should describe your problem a little more.
February 22, 2007, 07:52 |
Re: Rotating mesh
Are you asking if you can define mesh motion in cylindrical coordiates? If so, the sort answer is no, you can only define mesh motion in Cartesian coordinates. But you could easily generate some CEL to apply a rotational mesh motion.
February 22, 2007, 12:05 |
Re: Rotating mesh
#9 |
Firstly tanks for replying everyone!
The general idea is to rotate the mesh inkluding the bridge profil as a riged body movement (sorry for the misstake earlier) - but to keep the inflow direction constant. In this way the profile will expirience this as a varying angle of attack of the wind alpha = A*sin(omega*t) -and so simulating a marmonicaly movement of the profile with amplitude A and the circular frequency omega.In this way flutter derivatives can be determined. If further discription is needed just ask again. Once again thanks everyone. Regards Jesper |
February 22, 2007, 17:44 |
Re: Rotating mesh
#10 |
I can see two approaches being useful here. If the rigid motion timescales are slow compared to the fluid timescales you may be able to simulate this as a series of steady state simulations with a varying angle of the air at the inlet boundary. This will be a simple simulation and does not need moving mesh, rotating domains or anything. If the rigid motion timescales are similar to the fluid timescales then you are forced to do a fully coupled transient simulation. I would consider doing this using FSI, but if your bridge motion can be boiled down to a fairly simple equation of motion you might be able to do it entirely in CFX. Don't forget you are likely to have transverse motions as well as rotations so I would forget about rotating domains and just just general mesh motion. An example is the ball valve moving mesh tutorial. Glenn Horrocks |
February 23, 2007, 13:31 |
Re: Rotating mesh
#11 |
hey Glenn
Thanks for the response and yor great inputs/ideas. I know that transverse movement will occur, and these i know how to acount for - but rotating the mesh harmonically (or the angle of attck) is nessesary to do these calculations in tthe way mentioned earlier on. I have no acces to other programs than CFX, so this will have to do- sorry. Do you think it is possible, and if so - how to go about? tanks again regards Jesper |
February 25, 2007, 17:34 |
Re: Rotating mesh
#12 |
As long as you can write the equation of motion as a CEL expression it will work fine. Also I would only do the motion as a moving mesh simulation, forget about putting the rotating bit in a RFR. As long as the deflections are not huge (and for a bridge I hope they are not!) moving mesh should work fine. Glenn Horrocks |
February 26, 2007, 04:36 |
Re: Rotating mesh
#13 |
ok thanks Glenn.
I will definetly try that, but are almost certain it will not work, because simulating rater large angles is nessesary to conduct a flutter derivativ analysis. But you are right - in generalt the deflections are normally small for a bridge, but not when considering flutter - just recall the movements of the Tacoma Narrows bridge - though the motions today are some what smaller. But thanks for your interesst and inputs/help. If anyone have other surgestions or experiences with this, do not hesitate to write them here. regards Jesper |
April 27, 2012, 14:35 |
#14 | |
nizam
Rep Power: 14 |
April 27, 2012, 18:57 |
#15 |
Rep Power: 144 |
Examples of CEL are included in the CFX tutorials.
This old post is discussing rigid body motion coupled to fluid flow. This has been somewhat superseded by the 6DOF solver in recent releases which means you do not need to do program the basic motion any more, and a much better and more accurate scheme is built-in. |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
problem with rotating mesh | viet | CFX | 5 | March 10, 2007 00:16 |
rotating mesh | manohar | FLUENT | 3 | July 6, 2005 12:52 |
Multiple rotating frame VS dynamic mesh | Jen | FLUENT | 3 | July 2, 2005 07:31 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
