Difference b/t rotating wall and rotating domain?
Old   February 20, 2007, 02:22
Default Difference b/t rotating wall and rotating domain?
Juno Kim
Here is a confusing thing in simulating a pump. In general a rotating domain and a stationary domain are adopted for a pump simulaiton in CFX. I did it like the way. In stead of using the roating domain, could it be possible that the rotating blades and hub are set up rotating wall? Are there any difference?
Thanks in advance for your help.
Old   February 20, 2007, 11:03
Default Re: Difference b/t rotating wall and rotating doma
Bian
If you are not sure of the difference, you could try and see what would happen.
In a rotating domain, the fluid is subject to centrifugal force and the flow could be steady state in the rotating frame.
In a stationary domain, if you simulate the flow as transient with moving wall (and moving mesh), I assume you could get the same result. But, would the flow be steady state if you only set moving walls? Would the next position of the wall affect current flow field?
Old   February 20, 2007, 21:08
Default Thanks for your kind answer. (No message) *NM*
Juno Kim
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 23:43
Difference between domain motion and rotating wall 100tinela CFX 6 January 31, 2011 17:53
Rotating wall transient signal in CFX tiguiblais CFX 0 April 23, 2010 15:11
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 08:25
Counter rotating wall for rotating domain melvin CFX 0 February 4, 2008 05:51
