how to set the static pressure and total pressure
Old   May 31, 2021, 09:32
Post how to set the static pressure and total pressure
Springyuu
Springyuu is on a distinguished road
Hi, I'm doing a simulation that the air of 0.28 MPa flow into a tank of 100 Pa. There is a supersonic flow during the air flow. I choose the supersonic flow regime for the inlet boundary, and set the static pressure to 100 Pa and total pressure to 0.28 MPa due to the velocity is unknown.
however, I found that when the static pressure is 100 Pa, 200 Pa and other different values, the calculated mass flow rate on the inlet surface is different, respectively 0.0021 kg/s, 0.0034 kg/s, which are not in accordance with a formula. I also try to set the static pressure 0.28 MPa, but there is an error occurred that fatal overflow in linear solver.
So I wonder how should I set the static pressure and total pressure. if the static pressure should be set to 0.28 MPa, how to adjusting the settings. I will be very grateful if you can provide any suggestions. Thanks a lot!
Springyuu is offline   Reply With Quote
Old   May 31, 2021, 21:07
Before you start drawing conclusions about your results, have you confirmed you have reduced numerical errors sufficiently that the results are meaningful?
See FAQ: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Pressure fields in FOAM, p field, total pressure, etc. Tobi OpenFOAM Post-Processing 9 March 25, 2022 02:33
total pressure dynamic pressure static pressure roi247 FLUENT 19 February 4, 2020 13:52
What is difference between static pressure and gauge pressure? aja1345 FLUENT 1 July 20, 2018 21:05
Static or Total Pressure Inlet Boundary, Understanding problem Overdue CFX 13 August 4, 2016 08:25
Static vs Total Pressure Alfonso Ferrandez FLUENT 2 May 23, 2000 09:53
