display fortran calculations
Old   February 14, 2007, 05:59
Default display fortran calculations
isabel
Hi, everybody
I have computed the temperature gradient using fortran. I used it to send a momentum source in a subdomain.
I don't know how to verify if the fortran function returns the temperature gradient. How can I verify it? Can I have a display in CFX-Post to see fortran outputs?
Old   February 19, 2007, 08:37
Default Re: display fortran calculations
Johnson
Hi Isabel,
you can create an Algebraic Additional Variable and equate it to a User CEL Function which gets the temperature gradient through user fortran. The gradient components (Temperature.Gradient X/Y/Z) and magnitude will then be automatically created and stored as variable fields in the results file, which you can view in CFX-Post.
Regards,
Johnson
Fortran Compiler-CFX12.1 Araz CFX 13 March 27, 2017 06:37
display fortran calculations isabel CFX 1 September 17, 2007 16:52
Intrinsic Procedure 'ISNAN' in GNU FORTRAN 77 hawk Main CFD Forum 1 April 12, 2005 23:13
visual fortran Monica Main CFD Forum 1 August 28, 2004 21:45
Why Favoring Fortran over C/C++? Zi-Wei Chiou Main CFD Forum 35 September 26, 2001 10:34
