Problem about multi-phase analysis (Urgent)
Old   February 9, 2007, 09:18
Default Problem about multi-phase analysis (Urgent)
Prof. Lau (PolyU)
Now i am facing some problem on fluid analysis!!
1. how to perform analysis on mixing solid and water by CFX 2. The result is prefered to show a suspension effect at steady state. 3. To find minimum flow velocity for solid suspension
Thanks a lot!!!!!
Old   February 9, 2007, 11:45
Default Re: Problem about multi-phase analysis (Urgent)
Joe
Well start by doing the CFX tutorials then you can return with specific questions.
Old   February 9, 2007, 18:59
Astrid
That is not an question a Prof should ask...
Astrid
Need URGENT HELP for convergence problem of a turbine Pursuor CFX 5 October 3, 2011 18:44
Flow analysis in a Convergent-Divergent Nozzle (URGENT!) hasan_hzl ANSYS 2 June 30, 2009 01:46
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
Multi cycle analysis james Siemens 0 April 11, 2005 14:03
Two phase flow problem M.Shannag FLUENT 2 December 29, 2001 13:43
