February 8, 2007, 10:36 |
QUICK-Discretization Scheme
Hello everybody,
I have an issue concerning the QUICK-discretization scheme. I have performed two runs on a pretty coarse grid (about 600k element, 100k nodes, no special boundary layer resolution (that is pretty hight y+) and no densities in the wake regions) that was generated with ICEMCFD. I conducted two runs with the blend factor at sbf=0.75 and sbf=1 using the first run as initial solution for the second run. After that, I have tried to use the QUICK-scheme with the sbf=1-solution as the initial guess. With that configuration the solver crashed immediately, saying: ERROR #004100018 has occurred in subroutine FINMES. Message: Fatal overflow in linear solver. After that, I tried without an initial solution. This time the solver crashed after the first outer loop, saying: A wall has been placed at portion(s) of an OUTLET boundary condition (at 59.7% of the faces, 59.7% of the area) to prevent fluid from flowing into the domain. The boundary condition name is: OUT. The fluid name is: Air Ideal Gas. If this situation persists, consider switching to an Opening type boundary condition instead. ****** Notice ****** The maximum Mach number currently is 5.930E+03. If this message persists and you experience robustness problems,consider setting the expert parameter 'max continuity loops' to 2. ERROR #004100018 has occurred in subroutine FINMES. Message: Fatal overflow in linear solver. Did anyone ever have the same or similar problem an might know what the problem is? Regards and thank you Andreas |
February 8, 2007, 17:39 |
Re: QUICK-Discretization Scheme
A big problem with QUICK is that it is not very numerically stable, and I think that is exactly what you are experiencing. This is especially important for sonic flows - QUICK is terrible for sonic flows. In my experience QUICK is only good for low Mach number flows with very even grid spacing (or preferably constant grid spacing). I strongly recommend you use the High resolution differencing scheme as it is much more robust for sonic flows. There is a loss of formal accuracy to second order in general and first order at strong gradients but QUICK will have major boundedness and other stability problems so is unlikely to be more accurate. Glenn Horrocks |
February 9, 2007, 07:11 |
Hey Glenn,
thanks for your advice. One further issue with my flow - actually it is not sonic at all! I have a frees stream velocity of about 36 m/sec and maximum velocities of about 45 m/sec around my article. So the CFX-warning for my maximum Mach number confuses me even more. So I suppose that something is going totally wrong with the QUICK scheme... However I have no idea what it could be. Regards |
February 10, 2007, 00:46 |
If the flow is not high speed but it is giving warning messages about supersonic flows then something is seriously wrong. Either your simulation is diverging in a big way (go to high resolution differencing, it is much more stable) or your simulation setup is wrong. Glenn Horrocks |
May 24, 2010, 13:34 |
Help
Rep Power: 16 |
Hello everybody
I have encountered the error (some faces have been replaced with walls to prevent fluid flowing out or into the boundary) once i was solving flow in centrifugal compressor with cfx and QUICK scheme... |
May 24, 2010, 19:25 |
Rep Power: 144 |
It is not an error. It is a warning.
It just means that the inlet or outlet has reverse flow and it has stopped the reverse flow using artificial walls. This can occur when you use QUICK because it is allows resolution for finer features than the default scheme. |
May 29, 2010, 08:21 |
how can i use QUICK scheme?
May 29, 2010, 18:52 |
Rep Power: 144 |
You have to select it using CEL. Set up a run using some other differencign scheme and replace the entry with QUICK.
May 30, 2010, 03:51 |
#9 |
where can i read description of setting up QUICK scheme
May 30, 2010, 08:29 |
#10 |
Rep Power: 144 |
Not sure it is documented. To set it up you need to edit the CCL. Find the Spatial differencing key and change whatever is there (probably upwind or hybrid by default) and in a text editor change it to "QUICK". Reload the CCL and you will be using QUICK.
May 31, 2010, 16:08 |
#11 |
thanks in advance
July 26, 2019, 08:55 |
Problem with quick discretization
#12 |
Ali Baratian
Rep Power: 13 |
Hi every body
I have a problem with QUICK scheme In a 2d pure convection for 2 cells when i apply the scheme ij cell property phi eliminates and only neighbors remain! So how can i calculate the ij cell ? Just like the example in versteeg imean the dotted cells in pic attached Thanks in advance A11-ConvertImage.png |
July 27, 2019, 07:40 |
#13 |
Rep Power: 144 |
Are you asking how does the QUICK differencing scheme work? If so then look in any CFD textbook, Versteeg covers this I am sure. If this is not your question then please restate your question more clearly.
Implementation of QUICK scheme | Romuald Skoda | Main CFD Forum | 11 | November 6, 2017 22:20 |
Time discretization scheme | HaKu | Main CFD Forum | 1 | June 12, 2011 03:06 |
Discretization scheme for Convection Terms | Mohammad Kazemi | CFX | 16 | December 7, 2004 23:38 |
QUICK scheme | kim | FLUENT | 1 | August 29, 2002 11:16 |
MARS discretization scheme | raymond | Siemens | 3 | February 1, 2002 06:33 |
