number of the elements
Old   February 8, 2007, 02:40
Default number of the elements
eric
Dear Friends,
My modle has two parts, one little cylinder and a big cylinder. Mesh is generated in ICEM, tetra. Is it to know the number of the elements in each part?
Thank you in advance
eric
Old   February 9, 2007, 04:43
Default Re: number of the elements
Eric
Any suggestion? Thank you
Old   February 9, 2007, 09:36
jon
I am sure it is possible through mesher but one way is to import to pre, then right click on imported mesh and click mesh stats.
Old   February 9, 2007, 09:38
Eric
thank you.
But from CFX-post, we only konw the total number.
Many thanks.
Old   February 9, 2007, 09:41
jon
that is why i said pre! in pre it will allow you to click on different meshes.
Old   February 11, 2007, 22:24
eric
Maybe we only know the number of the surface mesn in each part.
Thanks
Old   February 12, 2007, 06:20
jon
Have you sorted it? I got confused?
You could make them and import them in seperate meshes, that way in pre you could know the count in each part aswell as the surface counts. your mesher should be able to tell you however but i dont use yours.
Appologies for the sarcasm it was a bad day!
Old   February 15, 2007, 01:32
eric
Thank you, Mr. Jon.
I tried. But I only get the number of the surface mesh.
If you have time, could you give me a picture of the result about mesh number.
Thank you in advance.
my email qiuyifa@hotmail.com
Old   February 16, 2007, 09:26
Dr. Flow Squad
Give them separate body names like Fluid1 and Fluid2. Create a dummy surface in between and mesh the total volume. Get the desired mesh info from Info/Mesh Info. The dummy surface can then either be deleted or act as Domain Interface in Pre
Old   February 16, 2007, 09:31
Eric
Dear Friends, Could you please tell me in details?
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
Smooth Grid Error! Help seasoul FLUENT 1 March 24, 2008 11:56
Number of elements in a mesh insignificant? Sam CFX 3 January 6, 2008 20:51
Finite element method - number of elements poornima Main CFD Forum 6 April 14, 2006 08:23
