Importan Problem In Parallel Solver
Old   February 6, 2007, 17:25
Default Importan Problem In Parallel Solver
Íñigo Guerrero Mendicoa
I cannot wonder the solution, and the people of ANSYS Support was not able to give me a solution after 10 mails.
When i run solver CFX 10.0 in parallel mode (boths MPICH or PVM), the proccesors freeze after 20 - 30 - 40 - 50 iterations. The RAM is 100% working and full.
The simulation is medium - large size.
All posible solution will be welcome, and would help me very much.
If someone need more information to help me, please, ask me.
My configuration is 4 machines Intel 64 bit Dual Core, with 8GB RAM each. I use Gbit Net to comunicate them.
I have a Red hat Linux Enterprise Ed. in all machines.
Thank you very much in advance. I look forward for a solution.
Old   February 7, 2007, 17:41
Default Re: Importan Problem In Parallel Solver
Does the machine just lock up or does it give an error message?
Old   February 8, 2007, 03:55
Íñigo
Hello Glenn,
only the proccessors stop, the RAM is completely operative, and i can run another programs, but CFX stops.
Regards
Old   February 8, 2007, 09:23
longbow
Couple of questions to you: 1. Do you have any problem to run your case with local parallel? 2. At the time processor is frozen, what is code doing? Is it writing backup file, during iteration, or at end of one iteration? 3. Have you sent your case to tech support so that they can try on their machine? You need to know whether your problem is machine-dependent or not.
Old   February 8, 2007, 12:47
Hello longbow,
1. In local parallel there is no problem,
2. Is during an iteration. And it doesn't depends of the phase of proccess. Sometimes in 10th iteration, sometimes in 60th iteration, in equals simulations
3. Yes, i sent the problem and the simulation that failed. They were not able to help me, and said me are studying the problem......
Old   February 8, 2007, 17:41
How reliable is your network? If you network has glitches or is occasionally heavily loaded from another user this could cause havoc to a distributed CFX run.
Old   February 8, 2007, 18:56
I don't think in the net could be the problem. I have a GBit connection, and on weekends and nights, when the local is empty, fall down too.
Could be something wrong with software, in memory allocation for instance?
Thanks, I look forward for more possible suggestions.
Old   February 9, 2007, 18:48
Astrid
Have seen somthing like this before when I had an expression with a reference to boundary. Something like:
InletVelocity = areaAve(velocity)@outlet
Do you have something like that? If so, then check if each partition has a part of the boundary you are refering to, outlet in my example. I had the problem resolved by defining a user difined direction for the partitioner, such that my outlet was present in each of my four partitions.
Another option can be to define a different expression..
Regs, Astrid
Old   February 10, 2007, 00:52
Hi
Astrid's comment seems to refer to a bug. Astrid, have you reported this to CFX support as a bug? Or even better, have you tested it on CFX11 and see if it still does it? If it is still there in CFX11 then definitely report it to CFX supprot. Then the problem can be fixed for all of us.
Inigo: Some networks have funny moments overnight as IT people do system backups and maintenance at night. Don't assume that because you are at home the network is working!
Your problem will take some fault finding to isolate I suspect. If you can't isolate the fault then call an IT person in to check if they can find a network problem causing your error.
Old   February 10, 2007, 16:52
HekLeR
Get cfx 11 and try it again. There was a problem fixed late in 11.0 which might cause the behaviour you observe.
Old   February 12, 2007, 19:14
  #11
Astrid
Yep, what I mentioned is recognized as a bug in CFX-10. Don't know if it is still present in CFX-11. Haven't tried it.
Regs, Astrid
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Solver problem in Oscillating Plate tutorial vovogoal CFX 1 November 22, 2011 10:54
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Divergence detected when using parallel solver Phil FLUENT 3 May 9, 2008 09:17
Parallel solver, divergence Phil FLUENT 0 April 30, 2008 10:42
