CGNS mesh and CFX 10.0
Old   February 5, 2007, 08:13
Default CGNS mesh and CFX 10.0
tiziano
Hi all, I have a home-made 2D mesh (ie, 3D mesh with olny 1 cell layer along Z direction) in CGNS format. It is a single block structured mesh, with 5 regions corresponding to 5 of the 6 faces of the block (defined by a ZoneBC node, in the cgns file). This mesh has been checked with ADFViewer to be correctly written and was working in CFX-5.7.
Now I am trying to import this mesh in cfx-pre 10.0. This time, it is not imported correctly: several "Intersecting 2D" regions appear instead of the previously defined regions. Funny enough, cxf-post 10.0 displays the mesh the right way.
Moreover, this happens only with 2D meshes: two layers of cells are imported.
Does anybody knows if there is a problem in CFX, importing cgns?
Thanks in advance.
[ICEM] CGNS mesh failing in CFX siw ANSYS Meshing & Geometry 5 November 23, 2017 20:07
How to red a Gambit mesh with Ansys CFX 10.0 jpsegura CFX 5 June 12, 2007 03:20
Problem on mesh import to Ansys CFX 10.0 Stephen Lau CFX 1 April 18, 2007 04:02
hex mesh using cfx mesh. mehul CFX 3 December 12, 2005 23:06
hex mesh using cfx mesh. mehul CFX 0 October 31, 2005 08:01
