Error in comparison of two cases with a domain at different locations CFD Post |
Aaditya
Rep Power: 5 ![]() |
I have two transient simulation cases for the same model of a radial turbine where one of the domains (the blade) in both the cases is at a different angle because of differences in timesteps. When I do the case comparison, the ANSYS does not show the difference between the two cases, instead, the view with the difference is just a blank screen. Does anyone know the reason for this and how to solve this issue?
Thank you! |
Gert-Jan
Rep Power: 27 ![]() |
I think that if the timesteps don't match, then Post can't compare them. Because the position of your turbine and mesh do not match.
In your case, I think you can only compare the final position (if they are similar) and compare time averaged results. And standard deviation, if you have caculated them. |
case comparison, cfd - post, contour plots, transient analysis |
Post Processing Results: Ansys Workbench 18.2 - Fluent - CFD Post - Porous Body | onlycfd | CFX | 4 | April 29, 2021 03:02 |
Post Processing Results: Ansys Workbench 18.2 - Fluent - CFD Post - Porous Body | onlycfd | FLUENT | 0 | April 28, 2021 23:41 |
[ICEM] How to generate an unstructured mesh for a 2 fluid domain rotor in ICEM CFD | Hazem24 | ANSYS Meshing & Geometry | 0 | December 21, 2020 06:52 |
Post processing journal - like .cst in CFD Post | Jiricbeng | FLUENT | 0 | April 24, 2019 08:08 |
CFD Post Case Comparison | akarlin | CFX | 0 | March 3, 2013 20:52 |
