Blade surface velocity distribution
Old   May 3, 2021, 04:54
Default Blade surface velocity distribution
Julian121 is on a distinguished road
I would like to draw blade surface veocity distributions corresponding to blade loading chart for a rotor blade in cfd post. I noticed that there are many types of velocity components such as velocity in stationary frame, velocity u v w, axial and so on. Which one of velocity should I use for this purpose?
Julian121 is offline   Reply With Quote
Old   May 3, 2021, 11:46
Kira
aero_head is on a distinguished road
I believe it would be the velocity in the freestream direction.
aero_head is offline   Reply With Quote
Old   May 6, 2021, 21:28
JiandongYan
Jiandong is on a distinguished road
Firstly, this would depend on which parameter you want to use to represent the blade loading. I don't think any velocity alone can represent the blade loading. I would recommond you to read through some introduction about D parameter, Deflection angel, etc.
Jiandong is offline   Reply With Quote
inflow velocity distribution is given by the Poiseuille flow Weiqiang Liu FLUENT 1 June 14, 2020 13:05
Mesh deformation using Surface file for a 3D turbine blade pgdelaserna SU2 0 May 29, 2019 13:22
Oscillating pressure distribution around a turbine blade, near the Trailing Edge Stuntmanbob OpenFOAM Pre-Processing 0 December 18, 2018 12:52
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
