January 27, 2007, 13:11 |
aerofoil problem
i have specific co-ordinates for a 2-d aerofoil. i have managed to construct the geometry in ansys by inputting the co-ordinateds in the command prompt. however i cannot seem to do this in workbench. any ideas as to how i can construct the geometry in workbench??
January 29, 2007, 22:02 |
Re: aerofoil problem
Try using DesignModeler.
January 30, 2007, 15:23 |
Where can you input specific co-ordinates in design modeller? seeing as i already have the aerofoil constructed in Ansys, is it not possible to simply import it to workbench or open it up somehow? thank you for your help on this it's much appreciated
January 30, 2007, 19:24 |
depending which ANSYS you have done it in, you should be able to save it as a IGIS file and import that into workbench.
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 08:27 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 09:39 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 15:52 |
