How to fix negative volume elements in icem cfd?
Old   January 25, 2007, 01:07
Default How to fix negative volume elements in icem cfd?
shirish
Hi friends, I have generated mesh in icem. I have negative volume elemnts. (determinanat is coming less than 1).Can anybody tell me that how i can fix this negative volume elemnts? I mean to say how can i correct them? Thanks you all
Old   January 25, 2007, 07:46
Default Re: How to fix negative volume elements in icem cf
Joe
Discussed ad nauseum already. Use the forum search function.
Old   January 26, 2007, 16:42
myron
If you're talking about a hex mesh - Edit Blocks > Fix Inverted Blocks. Then recompute the mesh. Should do it.
Old   January 28, 2007, 09:27
shirish
Thanks friend Should i select negative volume elements also? bcoz i have tride above suggestion but it could nt work. May be i do not know exact use of this tool? Pls can you specify how to use this tool?
Old   February 2, 2007, 03:22
Stephan
Look out for double vertices. Sometimes there are two vertices at the same position. This happens if you get confused during cutting blocks. Let ICEM show you the number of the vertices, so you can see if this is the reason. If it is, merge the vertices.
Old   June 5, 2018, 02:59
Red face Another way
MWRS
waseeqsiddiqui is on a distinguished road
If the negative elements are very few, delete them using the quality histogram and select the check mesh button to fix those uncovered volumes!
waseeqsiddiqui is offline   Reply With Quote
[ICEM] Problem with volume mesh in ICEM CFD kolapoasafa ANSYS Meshing & Geometry 2 September 16, 2011 04:54
Complex .stl data for volume meshing in ICEM CFD Nils_H ANSYS Meshing & Geometry 5 September 2, 2011 09:39
ICEM CFD Mesh Quality "Volume change" Paul Brainerd CFX 1 May 26, 2008 00:37
Negative volume in ICEM CFD hagupta CFX 4 June 30, 2006 07:20
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 07:46
