quistion about meshing
Old   January 16, 2007, 12:37
Default quistion about meshing
Zurayk
Hello, I want to make the meshing finer in some volume in the flow, not only along a line, but in a volume in the flow, to detect the shear layer better, can anyone tell me how to make the mesh finer in an interesting region?
Old   January 16, 2007, 13:45
Default Re: quistion about meshing
Santiago Orrego.
What program do you use? ICEM ? CFX Mesh?
Old   January 17, 2007, 03:54
Zurayk
CFX mesh is the program, please inform me if in ICEM i can solve the problem, I would consider using it then.
Old   January 17, 2007, 04:53
Michael B
Icem can easily do it. I've used "Create Mesh Density" in ICEM CFD for this example to enhance the details in the wake of the car.:
Old   January 17, 2007, 04:55
Fusion
Using ICEM you can do what you are asking by defining a "mesh density" on a surface.
Fusion
Old   January 17, 2007, 05:16
Zurayk
Thanx alot Michael and Fusion, I gotta try that.
Old   January 17, 2007, 08:47
Santiago Orrego.
ICEM its very "controlable". Its a difficult to learn "how" its works, but when you understand it, its very very good. Santiago.
Old   January 17, 2007, 13:46
Alex
For CFX-Mesh, you can try imprinting a surface in the region you are trying to resolve on a boundary in Design Modeler and then setting the desired face spacing for that imprinted face in CFX-Mesh. This at least allows you to control spacing more precisely inside a given boundary, instead of setting one value for the entire boundary. See CFX-Mesh Tutorial 9 for imprinting a surface. It is probably not as good as a density box in ICEM-CFD since you have to worry about how the mesh is changing in a third direction off the boundary, but it is the best I have come up with if stuck with CFX-Mesh.
Old   January 22, 2007, 05:03
zurayk
I found out that it is possible to mesh a region with CFX mesh through the workbench. this can happen by creating a plane in the area we wanna mesh finely and extrude a geometry there as freez. transfer it to the meshing and there we can create the triangle control from controls on the extruded geometry in region of interest. then before starting the surface mesh we just have to supress this extrusion we did. and then surface and volume mesh the modell. this will result in meshing the region of interest finely. Regards
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 12:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 06:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
