Ansys CFX Vs. NACA Summary Report. Mismatch Result
Old   January 12, 2007, 12:38
Default Ansys CFX Vs. NACA Summary Report. Mismatch Result
Santiago Orrego.
Hello. We are working on a NACA 4415 airfoil. We are trying to validate the model, making a comparation between the results from Ansys CFX and the summary report 824 from NACA, page 143.
The conditions of the NACA experimental Test are (if Im wrong please let me know): Re: 3e6 Density: 1.225 ???? kg/m3 Viscosity: 1.7986 ??? kg/m*s Chord= 2ft (0.6096m) Ref pressure= 1 atm ????
We assumed ISA conditions @ sea level. (if somebody know the conditions, please confirm us)
In CFX the conditions are: Re:3e6 Density: 1.225 kg/m3 Viscosity: 1.7986 kg/m*s Chord of the airfoil= 2ft (0.6096m) Ref pressure= 1 atm alfa= 4º turbulence model= SST turbulence intensity= 5% turbulence wall function=automatic Gas ideal @ 15ºC
for the iteration convergence: High resolution conservative max= 1e-4 autotimescale
meshed in ICEM. C grid hex elements, we used edge spacing, leaving the same spacing and changing number of nodes in the three meshes.
Hence: the results in CFX are: 1.Mesh: Elements 35466 - Y+:2.448 - Cd: 0.0301079 - Cl: 0.6131 2.Mesh: Elements 47886 - Y+:0.7881 - Cd: 0.029875 - Cl: 0.601245 3.Mesh: Elements 78606 - Y+:0.5475 - Cd: 0.0288936 - Cl: 0.589375
The results form NACA report are: Cl:0.81 Cd:0.0075
Can anybody can help us out? thanks for reading and contribuying.
Santiago - Andres - Colombia.
Old   January 13, 2007, 13:00
Default Re: Ansys CFX Vs. NACA Summary Report. Mismatch Re
Santiago Orrego.
Hello Again. We modified some boundary conditions and we got more closer.
Cl= 0.78 Cd=0.013
The error in Cl is about 7%, but the error in the Cd is about 60%.
Is this correct? its possible to get an error <10% in the Cd ?
Thanks Santiago Andres
Old   February 5, 2007, 10:31
bill
use transition model
Old   February 5, 2007, 13:05
Santiago Orrego.
Thanks Mr Bill. Ww used Langtry Menter and it worked ok. We had problems with the convergence, but the results where ok. Thanks santiago
Problem in coupling CFX and Ansys for fluid-thermal sim. Jordi CFX 21 March 1, 2017 06:03
ANSYS CFX Tutorial Rashid CFX 25 December 20, 2012 02:22
How to import CFX mesh & result to ANSYS Structure Ton CFX 2 May 19, 2009 22:54
Ansys CFX bucket problem njsavage Main CFD Forum 1 April 30, 2009 10:48
CFX bought by Ansys - good or bad?! Pete CFX 38 February 21, 2003 08:34
