April 4, 2021, 11:23 |
Define wall material
Alberto Fernandez
Rep Power: 5 |
I'm new using CFX and I'm working in a pre-made project. It's a compressor and I would like to define the wall material (shroud, hub and blade). For this, I think that I should work in Pre-CFX, not sure about this, because there is a material tab but I don't know how to say to the program that the walls are Aluminium.
April 5, 2021, 11:07 |
Rep Power: 33 |
Are you doing a CHT simulation, that is conjugate heat transfer?
If not, the material of the wall is not needed, i.e. irrelevant, for the simulation.
cfx, material, pre-cfx, wall |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 03:54 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 11:19 |
