How to mprove quality of Mesh
Old   January 11, 2007, 07:56
Default How to mprove quality of Mesh
aero
I have done hexa mesh to a model & converted it to Unstructed Mesh.I checked for Quality of Mesh.
Determinate ->0.58
Aspect-Ratio->0.1 (minimum)
Minimum Angle -> 4.7
but i wanted the above parameters with following values please tell me how to improve it.
Determinate -> 0.65
Aspect-Ratio-> 14(minimum)
Minimum Angle -> 13
Advanced Thanks & regards aero
Old   January 11, 2007, 09:52
Default Re: How to mprove quality of Mesh
Fusion
Which software are you using?
Fusion
Old   January 11, 2007, 16:33
Santiago Orrego.
Hello, how can I watch those parameters in ICEM ? Thanks santiago
Old   January 12, 2007, 03:54
Fusion
Under the tab "Edit Mesh" -> "Display Mesh Quality", you can select many quality criteria.
Fusion
Old   January 14, 2007, 08:26
matej
have a look at ansys web, you'll find demo room for ICEM. Go through the videos. I did learn a lot about the mesh handling there.
matej
Old   January 16, 2007, 07:35
Luke
to improve the aspect ratio you will have to either increase/decrease the number of nodes in the long/transverse direction. Angle can be improved by assuring that paralles edges have an identical distribution of nodes. And adjacent edges have almost equal first node distance at the common node.
[ICEM] Low quality Tet prism mesh saisanthoshm88 ANSYS Meshing & Geometry 17 September 28, 2016 17:50
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
