Transient Boundary Condition in Steady state solution |
March 30, 2021, 00:32 |
RAJDEEP JAGDALE
Rep Power: 8 |
Can constant magnitude of transient boundary condition provide well converged steady state solution?
March 30, 2021, 01:32 |
Bora
Rep Power: 9 |
Do you mean using a transient BC in a steady state simulation ? If not, in a transient simulation, constant magnitude of transient BC will yield in a "statistically steady state" solution with a sufficient run time. |
March 30, 2021, 02:24 |
RAJDEEP JAGDALE
Rep Power: 8 |
I mean by using Transient BC in Steady State Simulation like shaft rotation at particular constant speed which i am specifying in the CFX pre in rad/sec. |
March 30, 2021, 02:36 |
Rep Power: 144 |
Fluid flow is by its definition transient - the stuff is moving. But in a finite volume solver like CFX, if you can assume that when you define a volume you are simulating that the boundary conditions do not change with time and the fluid condition at all points in the volume do not change with time then it is a steady state simulation.
So think about whether the boundary condition changes the simulation volume. For example, if a wall has a tangential velocity this can be modelled by a tangential velocity on the wall but the simulation volume is not changed - therefore it is steady state. If you have a wall with a normal velocity this will change the simulation volume - therefore it is transient.
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
