"Good" Cluster configuration
Old   January 9, 2007, 13:54
Default "Good" Cluster configuration
Fusion
Dear all,
I have to buy a cluster for parallel calculation, I need some suggestions to define its configuration. I already have a cluster with 8 nodes, each of them have 2 AMD Opteron 2.8GHz processors and 4Gb RAM. The new cluster should have nearly the same computational power.
I have one more question: it is possible to reach the same performance in a cheaper way using standard PC in parallel configuration?
Thanks
Fusion
Old   January 10, 2007, 08:35
Default Re: "Good" Cluster configuration
Joe
Cheapest option: Single socket desktop Intel kentsdfield quad core eg. Q6600 or single socket server Xeon X32XX. 4 Cores each.
More expensive option: Dual socket server Intel Clovertown quad core eg. E53XX. 8 Cores each.
You may need to use bonded dual gige to provide sufficient internode network bandwidth.
Old   January 10, 2007, 18:36
There is extensive discussion of benchmarking on the CFX community webpage.
Joe - I have not seen anything to suggest high-end networking is required for small clusters. Obviously with multi-core CPUs this may change. Do you have any benchmarks here?
Small cluster configuration for pump simulation at CFX Nevel Hardware 2 April 7, 2014 07:07
Small cluster configuration for pump simulation at CFX Nevel CFX 3 February 3, 2010 23:37
Multiple Configuration Simulation Tristan CFX 0 November 14, 2009 00:01
Best cluster configuration ziad OpenFOAM Installation 15 September 21, 2007 13:36
CFX distributed computing: Cluster design Q Joe CFX 7 July 11, 2006 11:21
