hi,
According to CFX10 manual, looks like we can handel turbulence transition model. I want to set some parameters. I selected SST model, but there is not such as transition model tab at all. I tried to input from ccl, but it always says "it is not physically valid". What should I do to get access to the transition model? Thanks |
Its right there ... just under the turb model selection drop down.
i talked to an Ansys guy. Seems like we need to buy some sort of "advanced turbulence" license to activate this transition model.
Put this lines in the .pre file, because CFX 5.7.1 doesnt have a GUI option.
TURBULENCE MODEL: Option = SST TRANSITIONAL TURBULENCE: Option = Gamma Theta Model TRANSITION ONSET CORRELATION: Option = Langtry Menter END # ONSET CORRELATION END # TRANSITIONAL TURBULENCE END # TURBULENCE MODEL: And read the manual to know about other models. Hope it helps. |
I tried those lines, but in this time, I cant make converge the solution of a NACA airfoil. If anyody how make it converge, let me know please. Thanks santiago
Dear Steven and Santiago,
The transition model in ANSYS CFX has been evolving over the years (and releases).. It became visible in ANSYS CFX 10.0 which is a good reason not to use a previous version (in 5.7.1 was beta feature). Most important is that you require an additional license to use/access it. Please contact you CFX help desk or provider for information. Opaque. |
I made it converge, changing the Ratio to the mesh, to 1.02. Hope it helps santiago.
[ICEM] How to set bocos on 2D model for ANSYS CFX (tuts no help) | RossFS | ANSYS Meshing & Geometry | 4 | May 22, 2012 08:56 |
anybody using transition model in CFX | littlelz | CFX | 7 | May 11, 2011 06:48 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 22:04 |
modelling transition with v2f turbulence model | pablo | FLUENT | 0 | August 7, 2006 15:44 |
Help: 2D model in CFX 5.5 | Dejun Jing | CFX | 1 | July 24, 2002 00:25 |
