how to setup sub/super sonic mixed boundaries
Old   January 3, 2007, 12:26
Default how to setup sub/super sonic mixed boundaries
steven
hi,
We are running a turbine simulation. The inlet local Mach number is 0.15 while the outlet is 1.1. All other conditions are available (inlet pressure, outlet pressure, inlet velocity, outlet velocity etc). What is the best way to set boundary conditions? and what is the best model to simulate in CFX-10?
Thanks a lot
Old   January 9, 2007, 00:35
Default Re: how to setup sub/super sonic mixed boundaries
HekLeR
for this kind of case usually inlet total pressure & temperature with flow direction are used.
outlet... is that mach no. in the absolute or relative frame?
relative frame? you can use outlet static pressure or mass flow rate.
absolute frame? then probably a supersonic outlet and hope you can get the right pressure rise...
Old   January 9, 2007, 00:36
HekLeR
it's a turbine...
of course i mean pressure drop not rise.
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
How to setup two nonconformal boundaries as periodics? rikio FLUENT 3 June 27, 2012 09:02
periodic boundaries - flow through a net PK FLUENT 0 July 12, 2007 12:58
