the material parameters depending on temperature
Old   December 22, 2006, 02:51
Default the material parameters depending on temperature
Jason
Hi,all Now I have fifty groups number,the aluminium density depending on temperature.How can I add this to my material in cfx?
Maybe I can add this using CEL, Temp=Densitylower+(Densityupper-Densitylower)*(T-Templower)/(Tempupper-Templower)
But it is difficult as there are two many data . Maybe I can use the profile instead. I have no idea. Could someone give me some suggestions? Thank you in advance.
Jason
Old   December 22, 2006, 10:03
Default Re: the material parameters depending on temperatu
opaque
Dear Jason,
Read about 1D interpolation function in the ANSYS CFX-Pre manual. Then, you will input (Temperature,Density) pairs, and let the solver evaluate that for you..
Opaque
Old   December 22, 2006, 10:37
Jason
Dear Opaque :
Thank you for your help. It is very useful for me.
The Units in the Plot seems different from the "Result Units" .For example,I set the thermal conductivity [W m^-1 K^-1] in "result Units", and it turns out [kg m s^-3 K^-1] in the plot in the expression. Is it Okay?
Jason
Old   December 22, 2006, 10:57
opaque
Dear Jason,
[W] = [J s^-1] = [N m s^-1] = [kg m s^-2 m s^-1] = [kg m^2 s^-3]
[W m^-1 K^-1] = [kg m^2 s^-3 m^-1 K^-1]= = [kg m s^-3 K^-1]
I do not see any problem..
Opaque
Old   December 22, 2006, 20:54
Jason
Dear Opaque :
I got it. Thank you. yours
Jason
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
An issue with temperature change in unsteady prob Ashok kumar FLUENT 1 January 13, 2009 05:34
Temperature went outside of its upper limit Atit Koonsrisuk CFX 0 January 8, 2004 12:43
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
Temperature in vessel during throttling process Astrid Main CFD Forum 2 January 31, 2001 03:34
