pipe flow with normal injection through holes
Old   December 19, 2006, 15:01
Default pipe flow with normal injection through holes
Fred Song
The problem is: Water flows into a pipe which is closed at another end and has hundreds of holes along the axial length. The injection of water to the surrounding fluid from these holes is the major concern. The meshing of hundreds of holes and the region of the jets seems almost impossible to me. Any suggestions about meshing or alternatiev simulation approaches are highly appreciated!
Thanks and Regards!
Fred
Old   December 20, 2006, 08:16
Default Re: pipe flow with normal injection through holes
Joe
Do a single hole first. Then mesh a slice of the cylinder. Then do the whole thing.
And make sure whatever it is you want to know is worth all this effort.
Simulating hundreds of interacting VOF droplets will require a supercomputer.
Old   December 21, 2006, 11:42
aero
If geometry is symmetric, then use a sector of geometry to mesh & in CFX use periodic Boundary conditions.
Regards aero
Pipe flow with obstacle - HELP Min FLUENT 6 January 31, 2017 15:28
Pipe Flow Saima CFX 1 January 10, 2011 17:41
Turbulence intensity in fully devloped pipe flow - Reference Shocktrain Main CFD Forum 0 October 14, 2010 07:58
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 11:14
stepped pipe flow Tom Cloutier Main CFD Forum 0 April 20, 2003 14:19
