December 14, 2006, 19:26 |
meshing a Naca 4412 airfoil - help
hello. Im analysing a Naca4412, and I need some recomendations of the way that I should mesh the rectangle that contains the airfoil (low Re). 1. What kind of face Spacing? (Angular, relative error, constant, volumen spacing ?) 2. If I should create a new Face Space, and refine the mesh around the airfoil or create a control point and refine the mesh ? 3. how can I change the type of the element? and know the dimension, so I can extrude the 2D shape? 4. How many layers in Inflation? what configuration in teh inflation?
Thanks in advanced Santiago. |
December 17, 2006, 16:37 |
Re: meshing a Naca 4412 airfoil - help
These parameters depend on many things. Some things to consider are:
These parameters affect both the choice of physics to model and the mesh. Glenn Horrocks |
December 17, 2006, 21:05 |
1. Re=400.000
2. yes. 3. no. 4. no. 5. both. 6. not yet. Do you have a tutorial or paper that specify what kind of mesh do I need? or some kind o guidance? Thanks a lot santiago. |
December 18, 2006, 04:42 |
In that case you really only have one option which is to use the transition model in CFX. That has the following implications:
Hope that helps. I think you will find some validation examples of the transitional turbulence model on the CFX-community website. If not your CFX support person should have some. Glenn Horrocks |
[Other] Ansys meshing airfoil and / or compressor blades | baw192 | ANSYS Meshing & Geometry | 8 | September 23, 2011 00:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
[mesh tool] meshing airfoil naca 0015 | peter pan | ANSYS Meshing & Geometry | 0 | June 15, 2011 09:26 |
[GAMBIT] Meshing airfoil using .dat file problem | creggie | ANSYS Meshing & Geometry | 10 | June 27, 2010 19:24 |
Moving Mesh on 3D Airfoil NACA 4412 | nuovodna | OpenFOAM Running, Solving & CFD | 6 | January 3, 2008 11:03 |
