December 5, 2006, 07:04 |
How to import gtm-file into icem?
I have a gtm-file, that can be read in cfx-pre. But I need to modify the coordinate-axis direction and the names of the mesh-surfaces. How can I reimport the gtm-file into ICEM V10 to make the modifications? Thanks, Aloise |
December 5, 2006, 10:15 |
Re: How to import gtm-file into icem?
Write a def file out of Pre, then load the def file into ICEM CFD. Just create a dummy domain to do so.
-Robin |
December 5, 2006, 14:09 |
Thanks,
I did it that way, but I thought there must be another one. -Aloise |
December 5, 2006, 14:17 |
Now I`m importing the def-file via file-import mesh-from CFX5 But do you know what "Set face parts from": BC Patches or Surface means?
The entry in the helpfile didn`t help me a lot. -Aloise |
December 10, 2006, 20:24 |
There are two types of 2D regions in the def file, the boundary regions and your mesh regions (which may or may not be used for the boundar regions). The dialog is simply asking which you want to appear in ICEM CFD.
-Robin |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 08:11 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 02:08 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 05:26 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
