turbulent kinetic energy
Old   November 29, 2006, 13:37
Default turbulent kinetic energy
mike
Hi everybody,
I don't understand how I can see turbulent kinetic energy contours at no slip walls. Should not the values be zero at the walls? (I am using CFX10)
Thanks,
Mike
Old   November 29, 2006, 17:01
Default Re: turbulent kinetic energy
If you integrate the turbulence model to the wall it should be zero or near zero. If you use wall functions it will the value at the first node which will not be zero as it is assumed to be in the log layer.
Old   November 30, 2006, 09:31
mike
Thanks a lot Glenn,
Mike
question about turbulent kinetic energy junker4236 Main CFD Forum 19 April 19, 2017 05:46
LES and total turbulent kinetic energy Boerge FLUENT 1 September 8, 2012 12:41
LES of periodic pipe centerline turbulent kinetic energy smehdi609 OpenFOAM 0 December 1, 2010 00:59
what's the macro of SGS turbulent kinetic energy? lcw FLUENT 1 June 13, 2006 04:08
Turbulent Kinetic Energy Olga FLUENT 2 October 11, 2002 16:05
