January 19, 2021, 09:47 |
Additional scalar in CFX and
Davide
Rep Power: 11 |
I would to know how do you impose a scalar from a patch? Then I would simulate in an unsetady simulation the diffusion of this scalar, is it possible to do the cumulated over time of such a scalar at a point? Thank you |
January 19, 2021, 11:25 |
Rep Power: 33 |
You should benefit from doing tutorials using additional variables. Look in the documentation for "Additional Variables".
You can select the type of equation that governs the additional variable: transport equation, pure diffusion, or just Poisson equation. Once you select the equation type, you should provide boundary conditions on the "patches" of interest. The default value is zero flux for walls and required input for inlets. I read "accumulation over time" as "time integral of < something>" at a given location, correct? If so, you should benefit from reading the feature for monitor points where you can select to monitor the scalar at that specific location as well as the time integral, time average value, etc. Hope the above helps,
January 19, 2021, 13:28 |
#3 | |
Davide
Rep Power: 11 |
Yes, I wanted to say the time integral of the additional variable in way to do a contour in the space of this integrated additional variable in way to see at the end of the unsteady simulation what are the location in which it is been more present, is it possible? |
using a Fortran library of thermodynamics inside sutherland transport model | Mehdi3031 | OpenFOAM Programming & Development | 0 | April 7, 2016 09:34 |
Additional Variable Source Term in CFX | PranjalNewton | CFX | 1 | October 28, 2015 15:12 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
Limitation of CFX -11 ! solving scalar and MRF | Mohan R | CFX | 0 | September 8, 2008 01:45 |
How to delete additional variable in CFX Pre | Ahlo | CFX | 0 | August 21, 2008 12:34 |
