TBR Modeling(Fourier Transform) of Inlet Distortion in a Centrifugal Compressor Stage |
January 16, 2021, 14:52 |
Bora
Rep Power: 9 |
Hello Everyone,
I have been trying to solve 360 degree inlet distortion problem in a centrifugal compressor stage including inlet(stationary), rotor and diffuser domains. Normally, with a uniform total pressure inlet boundary condition, the setup is quite easy. However, I have been facing some problems with the distortion case. Up to now, I have tried several type Fourier Transforms (Rotational Boundary Disturbance, Rotor-Stator), but the results were not satisfying. I'd like to see smooth passing between the domains and 360 degree asymmetric flow distribution in each component when I open data instancing for each component in CFD post. I'd like to know, what kind of Fourier Transforms and how should I use for this problem ? In the attached file you can take a look on my setup view. Impeller has 13 main and splitter blades. Diffuser has 17 blades. Eventually, I want to observe the effect of the distortion on the surge margin of the stage. There is only 1 paper published related this model whic is: https://www.researchgate.net/publica...let_Distortion This however does not include a diffuser stage after rotor. |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 06:42 |
Can anyone tell me how to define inlet flow angle for a centrifugal turbine? | hntter | CFX | 0 | March 8, 2015 07:47 |
Problem with centrifugal pump calculation | Michiel | Main CFD Forum | 2 | June 17, 2012 21:32 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
How to set BCs for 3D double inlet centrifugal fan | siswara | FLUENT | 6 | July 5, 2001 01:47 |
