Meshing AutoCAD geometries using ICEM
Old   November 14, 2006, 08:09
Default Meshing AutoCAD geometries using ICEM
Yuqing
Dear All, I am trying to test the meshing capability of ICEM using AutoCAD 3D geometries. I don't have an AutoCAD software yet. Can anyone send me a simple geometry file for my testing. The AutoCAD file format I need is dwg or ACIS (.sat). It is easy to generate in AutoCAD, just go file>export, save type as ACIS(*.sat) then click save, and click on your model in the AutoCAD window. I can be contacted by email:
Yuqing.Feng@csiro.au
Thank you
Old   November 15, 2006, 16:03
Default Re: Meshing AutoCAD geometries using ICEM
myron
I have meshed many models from AutoCAD with no problems. Don't have any lying around - as I no longer use AutoCAD. As long as ICEM can read it in - it can be meshed.
Old   November 16, 2006, 21:08
Yuqing Feng
Thank you, Myron. Can I get your email and contact with you directly.-Yuqing
[ICEM] complex 2D meshing on ICEM kassab ANSYS Meshing & Geometry 26 April 14, 2014 22:02
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 18:08
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 11:09
ICEM Meshing Jaloha CFX 0 April 1, 2008 07:24
Missing tets along line when meshing with ICEM CFD Georges P. Côté CFX 6 March 23, 2006 01:34
